smutchin
Cat 6 Racer
- The Red Enclave
how is my test unscientific.
Are you for real?
'Which' is commercially driven and is based on opinion of the data presented which could be totally falsified.
Honestly try the test - no bulls*** here - its a practicle way to see if a helmets effective or not. - not made up statistics , no biased studies - its see for yourself time. you could varie the test to suit your personal take on how is my head going to the floor, you could kneal down and head but the pavement , you could try with the front, side or back of your head -
In the end you will you have a far better idea than reading every study ever done (most are utter nonesense and all are refuted with counter arguements) - so its make your own mind up, don't beleive others, don't be told things, go out and find out for yourself. - by doing it.
and yes I have tried both tests 1 and 2 (and 3 how "hard is helmet")
The problem is modern helmets only provide protection at low speed to the head surface (saving cuts and abrasions) - .
Today I wore no helmet for a leisurely ride with the girls on traffic free path.
A quite substantial tree branch hit me on the forehead
... Just saying ...![]()
The youngest: older ones have more respectIs "Hazardous Flora" the eldest or youngest of your branch swinging offspring?
Felt faint there for a minute. Must be the knock on the head.2485840 said:Thank you I would have been mortified to find I had offended you.
You're missing the point entirely. The Which? tests are consumer tests, not standards certification tests. [edit: to clarify further - they make no claims about whether or not a helmet will save your life in a real-world accident, they only test the relative ability of different helmets to absorb an impact (relative to each other and relative to not wearing a helmet), and iirc their tests cover a wider range of impacts (different angles, speeds etc) than the official BS or even SNELL tests. The point for Which? is not whether or not you should wear a helmet but if you do choose to buy one, which will perform the best. And the reason I brought it up was not to big up Which? but to highlight the difference between a proper product test and a bulls*** test.]
They don't just stick the fridges in a room and leave them, they carry out a wide range of tests on them.
The purpose of the tests isnot necessarily to recreate real-life conditions[edit: I should clarify that - the tests do recreate real-life conditions but not by direct imitation] but to ensure that all the different models are tested under identical circumstances, scientifically, in order to provide a truly fair comparison, in order that readers can make a fully informed choice when choosing which fridge or cycle helmet or whatever to buy.
Most publications that run consumer product tests just use whatever free stuff the manufacturers send them, spend half an hour "testing" them, then write up their opinions. If you're happy to take their opinions on trust, that's up to you. Personally, I take most of them except Which? with a pinch of salt.
But that's just, like, my opinion, man.
