Fiona N
I think BMI is good as an epidemiological tool - looking at whole populations but, if you're not a normal unfit, flabby person (i.e. you're a fit cyclist or other athlete) then the chances of it throwing up some odd things is high.
For example, I'm 1.69m tall and racing weight 25 years ago was around 59kg - I tried never to drop below this as it corresponded to a (properly measured) body fat of only 10% which is getting unhealthily low for a young woman. But the numbers give a BMI of over 20 - so in the middle of the normal weight range. The thing is I'm muscled (or was then) rather like Chris Hoy. Even now, my lean bodyweight (i.e. minus the fat) is still close to 53kg as I do sufficient weight-bearing exercise to maintain it. Keeping a check on body fat percent is probably a better guide than BMI if you tend to a muscular physique.
