suecsi
- Feltham, Middlesex
Agree with marinyork - I only work 10 miles from home, and do a mixed mode commute with the Brompton. Inevitably, there can be numpties at both ends, but most of the time the difference can be seen between the home end - some dedicated cycle lanes, off and on road (absolutely minimum width), with the on pavement ones usually filled with broken glass and the paint and surface degraded. On road ones often have commercial vehicles parked in them between 8am-6pm.
Dominance of WVM and Courier vans associated with the airport, lots of HGVs. A straight, long former Roman Road with absolutely no attempt to curb speed (supposed to be 30 or 40mph) but it isn't unusual to have cars doing a good 50-60 regularly, and later at night it is a complete rat run with even higher speeds. Often beeped to 'get in the cycle lane/path' when there isn't one, or on a road which is plenty wide enough to pass, and I'm not using the on road cycle path as there is a bl**dy great pick up parked in it outside the steel works (which has a nasty habit of disposing of its metal shavings by the kerb).
At the work end, there is a network of cycle paths, both on road, on pavement, or on road but segregated by a kerb. There are also several quiet back roads, part of the NCN, so with a combination of these and the paths above, there isn't too much need to go on the main roads, in fact it can be slower. You will see experienced (and 99% of the time, seriously lycra clad) cyclists on the ring road, but they are fast enough to keep up with the traffic, which is the fast race track style common with one way ring roads. They're often on their way to Sigma Sport, over the bridge in Hampton Wick. Whilst the provision is nothing like the 'utopia' offered by the Dutch system (for fans of a segrationalist approach) I think the facilities are indicative of the fact the majority of the road system was rebuilt from scratch at the end of the 1980s when the main shopping area - formerly a through road - was pedestrianised - and the council seemed to have some sensible planners that took cycling into account.
Both ends of my commute are in London Boroughs.
