classic33
Leg End Member
If what you use for securing and alarming your cycle, causes either injury or upset to someone trying to remove it. Should you be blamed?
"Brown trouser" moment, no injury, when the alarm was set off. Kranks Alarm in use at home. He wasn't expecting an alarm to be in use.
This caused him to get his arm jammed slightly in the frame. Chain runs through both parts, then into a ground anchor.
I'm assuming he was trying to work out where the chain ran, when he set the alarm off.
