Alan Farroll
But is it Finish line Ceramic Wax lube, finish line ceramic dry lube or finish line ceramic wet lube?Finish Line Ceramic - have yet to find a better lube.
Thanks
Dry ceramic wax. Use it very sparingly, a drop per link with a cloth underneath to catch any excess, then use the cloth with the "wet patch" to wipe the chain to distribute the lube even,y over the chain. You'll need to reapply it after every wet ride, but otherwise it does a great job of stopping stuff sticking to the chain in the first place.But is it Finish line Ceramic Wax lube, finish line ceramic dry lube or finish line ceramic wet lube?
Thanks
Yes, that's the stuff. Shop around, you should be able to save ten bob or so over Tredz priceThanks. This is good advise. I purchased the following. I am assuming this is a Dry lube although it doesn't actually state "Dry" but there is a similar product that does state it is "Wet" so I have assumed the link below is a "Dry". If not what is it?
http://www.tredz.co.uk/.Finish-Line-Ceramic-Wax-120-ml-Lubricant-Bottle_25843.htm
My thanks to all on the advise on this thread
Alan
If you keep your eye on the Lidl or Aldi weekly bargains these turn up from time to time. I have one and it is perfectly useableThanks again to everyone who contributed. I have ordered Finish line ceramic dry wax lube and copper anti seize grease from Tredz website. I am going to build my own repair stand as a decent one is expensive to buy.
Thank you
Alan
Thank you
Alan
Oh and these are incredibly cheap, costs 30USD$ per year.I negate the need for pedal grease unless completely dry, but i use wd40 or white lightning to clean the drive, then i oil it up with rock'n'roll chain lube, it is waxy so works well in my dusty unpredictable climate.
Thank you
Alan
