Cutting the steering post
Jimmy Welch
Hi All
I want to drop my bars down to a lower position and so I have a lot of spacers now sitting above the cap which looks odd, so next step is to cut the post down but there is a star fangled nut to contend with , it's a Cannondale Synapse Aluminum 2014 bike and from the videos I have watched I can't see if you push the nut down to a place just below ie 3mm , the new lip or do you push it way down and fit a new nut , but either way how do I get the nut to exactly were it needs to be
Cheers
Lozz360
Oxfordshire
You push it down far enough so it can still easily be reached by the stem cap screw. There is a GCN video that explains the process very well.
si_c
Wirral
Use something like a 1" diameter socket and slowly tap it to just below the line you want to cut, then once you've cut the steerer tap it down into it's final position - keep track of how far below the top of the steerer it is now and get it into roughly the same position.
Deleted member 1258
I would ride the bike for a month or two with the spacers above the stem before cutting the steerer down, in case you change your mind!
I never got round to trimming the steerer on the Verenti I had, When I sold it earlier this year it had still got the spacers above the stem.
lejogger
Wirral
Taking one of mine to the LBS tomorrow for them to do this for me.
Not something you want to mess up, so while I'm happy to do the vast majority of maintenance myself, this is one that I'm happy to pay a small fee for!
JoeyB
Go on, tilt your head!
^This - Happily built a few bikes up from framesets now but some things I just like to hand off to my trusty LBS for piece of mind.
si_c
Wirral
Done it a couple of times, not too difficult with a metal steerer, especially if you have a vice block for it, but I wouldn't want to do it on a carbon tube. That being said if it was egregious I'd get it done at the same time as getting any facing (BB, disc mounts etc) done on a frameset build.
Venod
Eh up
Yorkshire
A couple of Jubilee Clips or similar the width of a saw blade apart are a good substitute for the special jig you can buy, I have cut several carbon steerers this way.
I find the starnut offensive, a proper bung as used on carbon steerers is a much better engineered solution.
J
Jimmy Welch
Too much ?? I've gone and cut it wasnt too much trouble
