Thanks for the reply.
So with mudguards do you think 28mm tyres would fit as you said your 25s are tight
Also I noticed the 56 frame seems on small size - wonder whether I would need 58 . I'm 6ft
Cheers
Nope you don't mind me dragging up this thread, I've purchased the cube attain disc too and I'm running 28mm 4 seasons on it but on my last 2 spins the rear guard has loosened on me on the bridge and started rubbing badly.
I've given it a squeeze with an Allen key but it seems to slip down and the rubber pads slide up, reading the instructions it says to tighten the bridge bolt to 4 to 5 newtons, that seems very tight and I'm wondering if anyone has done this and no problem?
Thank you - I will do that and that should solve my problem.Yes, that's what I did - 4.5 Nm. The bridge hasn't budged. I suspect the seatstays can tolerate considerably higher.
first post on here as have been following this thread for a while now... I gave up on cube supplying any mudguards so have fitted sks bluemells 35mm with adaptors from sks to screw in the offset holes in forks and rear.. these adaptors were only £2-50 a pair and I just had to thin the rubber mount on the front mudguard arms to allow it to fit between the adaptor.. the rear was fine as it was metal so thinner..the missing seat stay mount was cured by using the bow tie adaptor that comes with a set of giant defy specific mudguards and this cable ties neatly and securely in place.. I had to male a little extender to go from the bowtie to the mudguard eye as the distance was too much because it sits a bit higher than the cube clamp on thing which you cant get anyway..the result is I am running 28mm gp400s on hunt aero disc wheels which are quite wide with no rubbing at all on 500 miles of riding in all weathers..overall very pleased with the bike and I think these guards will last much longer than the cube ones which I doubt will ever be made again
Mine have been going fine since install, bike is only used in the winter so helps, the back one has gotten a bit loose but fine. I was lucky enough to purchase 2 sets of the cubeguards with the bike so have a new set in a box just in case these give up.Thanks Origamist - thanks did the trick and no movement since. Im running the cube guards over 28mm Conti 4 seasons and no issues.
These mudguards are now available again from cube, ordered 2 sets today of them.
