Cube Analog 29
A
Alan16ac
Just though I'd finish this off.
I went for a 29 in the end but got the Cube Acid instead at £799.
Drago
The Urban Fringe
My Cube rides very nicely. And the "bling" makes for smooth gear changes, easy braking, and a controlled ride from the air forks.
I'm very pleased to hear it. All to often the bling is bolted to a frame that's too flexi or, more likely these days, simply has the geometry all wrong. All the XT or Fox Float in the World won't compensate for that.
Just out of interest, what suspension pressures and sag are you running for your weight, ad where do you get the forks serviced?
