Sheldon Brown explains why, but I'm not sure I grasp it:
Most bicycles with handlebar-mounted shifters run the rear cable on the right, the front on the left. This causes some awkwardness in routing the length of housing from the shift lever to the frame stops. Due to the need to allow these housings to be long enough to permit the bars to be turned all the way back and forth, the housings often wind up making a reverse bend--for instance, the rear will go from the shifter, which is on the right, swing forward and cross over past the centerline of the bicycle, then back over to the right side of the top tube, before heading down the down tube. These extra bends increase friction, and the fairly forcible contact between the housing and the side of the top tube can damage the finish.
A neat solution to this is to run the cables "criss-cross" style: The rear runs from the lever, (on the right) around the top tube, and to the cable stop on the left side of the downtube! The front cable crosses over similarly from the left side of the handlebar to the right side of the down tube.
The bare cables then cross one another under the middle of the downtube, making an "X". The cables may touch where they cross, but they will do so very lightly, since they are both straight...the tiny bit of friction at this crossing is more than offset by the reduction in friction in the smoother-flowing cable housings.
This technique does not work with over-the-bottom-bracket cable routing, but is doable with most newer bikes that have under-the-bottom-bracket cable routing and cable stops mounted toward the bottom side of the down tube.
