Looks like I've knackered the thread.
Anyone know where to get a compatible spare ?
Bolt says
120mm M12 X P1.5 X L14.
Struggling to find one that's exactly the same markings ? Anyone able to help ? Thanks.
Good points.Hate to ask, but how? Seeing as the thread is aligned by the opposite drop-out surely it can only thread in squarely.
Also, if the axle thread is fubar'd what state is the frame insert in?
It's a titanium gravel bike. Selcof carbon front fork. Maybe I should search on that. Ta.What make forks ? You usually get the same - i.e. Rockshox, Fox etc.
Other option, and not cheap - SJS Cycles for the Roberts Axel Project.
Thanks for this ! Good explanation !Axle Length 120mm
Bolt size is M12
Thread Pitch is 1.5
Thread length is 14
You can be slightly flexible on the thread length.
Sorry I realised I forgot the important link to one that will work - https://www.wiggle.co.uk/prime-lightweight-road-disc-thru-axle?Thanks for this ! Good explanation !
Thanks Milkfloat - out walking the dog so just seen this. I also emailed Planet X before I went out and they advised that they have one that will fit if I have a Torx 40 key. I'm sure I do so will post that link in case anyone gets stuck like me.Sorry I realised I forgot the important link to one that will work - https://www.wiggle.co.uk/prime-lightweight-road-disc-thru-axle?
Option 1 120/15/M12*P1.5
Ooh. Worth a go ! Will try later. Ta.Try putting the bolt in from the other side. You may be able to recut the thread sufficient to get a grip from the correct side.
maybe not!!!!Ooh. Worth a go ! Will try later. Ta.
How is it compromising? What is it compromising?maybe not!!!!
This holds your front wheel on. Don't compromise.
