w00hoo_kent
One of the 64K
 - Maidstone or Greenwich
Quick background, (yeah, probably not that quick) when I started cycling again I did it with a triple. I started looking for another bike and a friend explained cross chaining to me and said I'd be better off with a double (or double compact) because then I could use all of the gears rather than avoiding loads. Plus, in Kent, I never used the smallest cog. So I made sure that was near the top of my list. Fast forward to the Ride London, I'm hearing some odd noises from my chain ring in 'top/top' and waste some time queuing to check with the mechanic that it isn't an issue. First thing he does is look at my chain and berate me for being in the big ring, but a couple of gears away from the biggest cog on the cassette because 'cross chaining like that won't be doing anything any good'.
Aside from the fact I was in that gearing because I'd slowed down for the hub and was ticking along at walking pace, is it really that bad? On a double ring set up are there still areas of the cassette you shouldn't go in to for good reason? If so, should I just give up and go to a 1 by 5 set up, because surely a 1 by 10 would be just as terrible for everything. Or was the guy just being grumpy because he'd had to deal with a thousand punctures already and would only be happy if a single speed turned up?
