Monsieur Remings
- Yatton UK
I know there was a thread sometime ago on this light.
Well, I have one but there is a problem with the 2-pin charger. Firstly it won't stay in a standard shaving plug without fiddling around to get the red light which tells me it's charging, and I know it needs it. Secondly, the charger managed to short/blow an adaptor which converted amongst other things that 2-pin arrangement to a standard UK plug. Thirdly, when I plug the battery to the charger, even when the charger is not plugged in it gives off a green light suggesting to me that the power is running the wrong way!
So, anybody got one of these and can suggest a solution I'd be well chuffed. Basically the battery connects to the light and works a pack on the bike and then you take the battery off the bike and link it to the charger using the same arrangement. Now, i If I need to I'll use another battery pack but any suggestions? Surely there must be a charger that is compatible somewhere or a firm/outlet that sells these lights somewhere in UK.
