- South Manchester
Sorry i meant it last about 30 mins on full power before it goes red .I did drop the battery the other day .
Probably the same. Dead cell.
Do we know how good the cells are in these packs from C&B Seen?and one 18650 4 cell rubberised battery off C&B seen coming my way
Cheers Ed
not sure yet as it hasn't arrived but i just went with them as various people on here recommended me to and i hadn't a clue otherwise! will post on here to tell you it hasn't failed when it turned up but unless you want to wait a year or so for me to properly test it before you buy then i would say just take the riskDo we know how good the cells are in these packs from C&B Seen?
Am tempted to get one or would the highest capacity Xtar ones be better?
will wait until it comes and see how bad it is and decide weather or not i need it but probably will end up getting itlikewise on the battery getting flakier. I'm going for the C&B... battery option this time round.
@young Ed Might I also suggest you nip back to C&B..... and buy a fresnel glass for the unit. they're about a fiver & make the beam pattern a touch more rectangular than conical, it helps for you to see by as you have a wider lateral throw for no less forward illumination and makes it less dazzling for oncoming drivers and passing aircraft.
Ok I'll repeat myself.
Cree DO NOT make bicycle front lights/headlights. They manufacture LED chips and circuit boards.
What you are buying here is a product of questionable quality and even worse, an unknown LIPO battery also of questionable quality.
View: http://youtu.be/QjkW3KUz5uo
is it one of those CandBseen ones? the one with the silicone case? are you using it with a T6 like this IIRC?6 cell came yesterday , i will report on monday![]()
http://www.ebay.co.uk/itm/400705535843could i have a link, just IN CASE C&Bseen isn't any good. won't order until i have a replacement from C&Bseen though
Cheers Ed
is the front light too much of a draw for your battery so the battery goes into protection mode or something like that?I have 2 of the C&B packs for my rear lights. They are about 4400 ish. They do 2 hours plus on my rear lights.
They won't support my front lights, so i use a custom pack.
very well with the lightWould be interested to hear how you get on with these @young Ed
as you haven't reported back i'm guessing the battery failed and you are now somewhat injured?6 cell came yesterday , i will report on monday![]()
