Creaky headset?
potsy
Rambler
My Armchair
Ok, so I have a creaking noise coming from somewhere on the bike, seems like it's towards the front forks/headset/stem/bars area :unsure:
Worse when I'm going uphill and pulling on the bars which leads me to think it's stem/headset related.
I slightly tightened the headset the other day, not too much but it's made no real difference, would taking it apart and re-greasing help?
If I do this how easy is it?
ps- the bike is not quite a year old so would I be best taking it back to the lbs or will they count creaks as normal wear and tear?
martint235
Dog on a bike
Welling
Overtightened it is my guess. Mine creaks if I overtighten it.
marzjennings
Maybe grit/dirt caught between bar and stem and steerer tube. Take a note of how your bars are currently set up and then strip down, clean thoroughly, rebuild. Should take about 10-20mins.
My saddle starts to creak after the 4-5th ride after every clean up. I take it off, clean it and I'm good to go.
martint235
Dog on a bike
Welling
It was creaking before though Martin, I thought this might help.
Only started a few weeks ago :scratch:
Take it apart then just making sure it all goes back the same way. Make sure the races are clean. If it's still creaking after that, it may need a new headset. It's not a Giant is it?
potsy
potsy
Rambler
My Armchair
Thanks, sounds like a good clean and grease then over the weekend, headsets are a part of the bike I have yet to tackle, the Secteur's has never been touched in nearly 3 years and 9000 miles.
This one is 9 months and 3000 miles old, it's a Tricross Martin.
ianrauk
Tattooed Beat Messiah
Rides Ti2
It's very easy to take apart, clean, re-grease and put together.
Have a go Pots.
zeb
I had exactly the same issue a couple of weeks ago. My headset is semi-integrated (internal to the head tube, but with cups) with loose beads. Disassembling, cleaning regreasing and reassembling was easy and solved the issue completely.​
Beware if your headset uses loose beads not to lose them! You may consider replacing the beads (they are so cheap), and use a good grease (I use Finish Line with Teflon, great stuff) generously. Originally, there was just a thin oil, no wonder grit was able to enter the headset mechanism.​
ianrauk
Rides Ti2
Potsy's bike will have 2 set's of sealed bearings and a stop shim.
Just a case of dropping the forks, out with the bearings, clean, grease and replace.
zeb
You mean an internal (or integrated) bearing? A bit off topic, but Chris King made a paper saying this was not good because they had no cups, and that head tubes could not be machined with a precision as high as external or semi-integrated cups., is this correct? I have seen many high-end bikes like Trek using them anyway. Has the technology improved?
zeb
You mean the actual disc caliper?
This is getting more complicated ;)
When you unscrew the top cap of yoour fork (above the bars) then the fork can be pull down completely. If you are unsure, you should go to a LBS. Furthermore, they would easily identify the bearings you'll need. There are several headset types and sub-types..
