The problem with the adjustable stems I've seen was a bolt that "fixes" the angular position by going through a threaded clamp hole at the same side as the bolts head, with the bolts tip pressing on the tube wall the clamp is on.
When tensioning the bolt it exerts a pushing eachother away force between clamp and tube dead ends. That is the "fixing".
Poor, because nothing at the other side of the tube wall (alike a nut and required longer bolt would have been) tensions "through" the two mounted parts, holding them together that way. Any deformation of plate and tube causes wiggling room and deformation of the plate is precisely what happens when tensioning the bolt, and also the bolts tip grinds off material of the bar it pushes against.
On top of that problem, this plate has a number of horizontal ridges in order to give grip on the tube wall, which also has ridges. But when you cycle, you exert just like pedals, an alternating force left / right which wears the alloy sides away from the ridges, reduce even further their width, further aggravating the problem.
At some point I dumped the "adjustable" and the cyclical returns of creaking sound disappeared with it.
