wam68
have you checked the crank bolts torque ?[/QUOTE
They are tight and seem ok.
Or the reverse, as I found yesterday after fitting new wheels.Also unlikely but creaks can sometimes just be overtightened skewer(s).
Bertie it all started when under load and then progressed to free wheeling. It's like its got its own fecking personality. I am slowly but surely removing causes ie headset, cranks, pedals, seat stem , axle bearings and now am left with either BB or free hub.have you got a spare wheel to swap , surely if its worse when freewheeling you can rule out crank , chain or gears , if you stand up while freewheeling and it still does it then you can rule out seat only leaving handlebar area wheels or peddles ?
Hope your right. The bearings in the axle where red with rust on the hub side with no grease evident. I can only put this down to the frequent use of degreaser on the cassettte. On the non drive side the bearings were shining like new pins in a clean bed of grease. Have replaced them all and will give it all a good run out on Friday( taking a half day to sort it out ). New BB is here so the weekend is going to finally sort this out. Will let you all know what happened. Thanks for all your kind advice.to me if it does it when the crank is not moving and has got worse i would have said wheel bearings - when mine went it started when putting pressure on but in the end they sounded bad at anytime , then go quiet then back with vengance . stand your bike up and see if the wheel wobbles when you try moving it side to side - or take it off and see if the axle grinds when you move it with your fingers . only guessing but thats how mine went
though it might be your filangee !
. Thanks everybody for the input. It was a great help.
. Wifey couldn't see why it was such a problem
