a-n-wilson
Hi, I've got a Specislised roubaix pro 2018 with s works cranks on an OSBB. I think that a bearing has loosened, which has pushed out a collar.
I reckon that all I need to do to fix it is take the cranks off then push it back into place,but the problem is that I can't take the cranks off!
I can undo the one Allen key bolt up to a point, but then it tightens again. There's a collar over the top of it with two small indentations, I'm wondering if this needs to have something done to it.
So, does anyone have any ideas what I can do to get past the point that the bolt starts to retighten and do get the cranks off? If you can help, it would be much appreciated as I'm going stir crazy being stuck in! Many thanks.
