Totally agree about a smear of grease on the tapers of the b/b axle. I know a lot of people say it is a no-no and that it prevents a perfectly tight interface between crank and axle, but I've never yet had a problem and it does facilitate crank removal for sure.
The risk is that the hole in the relatively soft aluminium crank gets larger and larger, and the stresses around the hole get higher and higher. This happens because the expansion force of the tapered spindle on the crank is much more powerful when the effects of friction are reduced. At some point the crank may be so far onto the spindle that the bolt bottoms out on the spindle and cannot properly secure the crank, or the crank may start cracking at the corners of the square hole. I'm not saying it will happen every time, but many years ago I used to lube the taper for the same reason you suggest, and eventually I had a cracked crank to show for it.
Edit: It's the crank that suffers rather than the spindle, because the spindle is usually steel, and the crank is almost invariably aluminium.
