LarryDuff
- Hillsborough Co Down
If I want to know my crank length, where do I need to measure from and to?
Thanks
Thanks
Centre to centre, mind it's normally stamped/cast into the inside of the crankarms
Or 170mm as it's known !
Damned new fangled measurements!
0.17m would be the proper SI measurement![]()
Nah there are 2 measurements in standard units Millimetres and Metres, the centimetre was dropped years ago
On a fixie next to those fun elevated safety borders the 5 mm can make the difference between going horizontal and going vertical, something you noticeCentre to centre. The difference between 170 & 175mm is minimal. You won't notice it.
Of course, there has been the view that if you're serious, even 5mm. can make a lot of difference in spinning comfort & efficiency.The difference between 170 & 175mm is minimal. You won't notice it.
Thanks
