Yes indeed, I raised it up a few mm only to reduce a slight rub mind.There is a 4mm difference in radius between a 52 and 50-tooth chainring.
The height of a FD above the largest chainring should be 2mm.
You've introduced a difference of 4mm.
Go figure.
Blimey - how many times have you done it?!I've never had to touch the front mech on my CAAD when I've done the same, never had to alter the chain either it's always been a straight swap![]()
Quite a few. I decide I'm fit enough to put the 52 back on, then everything goes out the window, fitness drops off a cliff and the compact goes back on 🤣Blimey - how many times have you done it?!![]()
I’m hoping the opposite happens & I can go 53/39 with a 32t. You never know, we all need a little dream.Quite a few. I decide I'm fit enough to put the 52 back on, then everything goes out the window, fitness drops off a cliff and the compact goes back on 🤣
I'm doing something similar... I have a 46/34 on my CAADX but need to change it to a 53/39. My cousin kindly donated his old Powercranks but the only bike I have with the required BB30 BB is the CAADX. The spider won't take small rings.I’m hoping the opposite happens & I can go 53/39 with a 32t. You never know, we all need a little dream.
I suppose on a gravel style bike with a big 42on the back, pro rings will be great!I'm doing something similar... I have a 46/34 on my CAADX but need to change it to a 53/39. My cousin kindly donated his old Powercranks but the only bike I have with the required BB30 BB is the CAADX. The spider won't take small rings.
(Mind you, I am going to cheat and fit a crazily huge 42-tooth replacement sprocket to my cassette!)
That's the plan. I will have to lose a sprocket in the middle of the cassette but I reckon I can put up with that!I suppose on a gravel style bike with a big 42on the back, pro rings will be great!
I’m looking at CAADX & Cube Nuroad for Possible cycle to workers next year. Cotic Escapade a contender along with the Canyon grail AL.That's the plan. I will have to lose a sprocket in the middle of the cassette but I reckon I can put up with that!
I bought my CAADX on eBay for about 50% of list price. It had been used for a year of commuting but was still in very good condition. The original tyres had been swapped out for the commute and put back for the sale so they were unused.I’m looking at CAADX & Cube Nuroad for Possible cycle to workers next year. Cotic Escapade a contender along with the Canyon grail AL.
