Crank/Chainset fitting
pubrunner
Hi All,
I'm fitting a new square taper chainset and my query is this;
Should I put grease on the bottom bracket spindle shaft - the part onto which the chainset fits ? (Some websites seem to recommend 'dry' fitting) - might this not make them difficult to remove at some later date ?
Which grease would be best - lithium, copper or something else.
Also, which would be the best grease to put on the crank bolts ?
I've never fitted a crank/chainset before, so I'd appreciate any advice.
Thank you
raindog
er.....
France
They're usually dry fit. If you use grease there's a risk of distorting the tapered hole in the crank.
PpPete
Chandler's Ford
If re-using an old spindle make sure the crank bolt threads are clean - WD40 is fine for this. I've never used either loctite or grease on the bolts. But since reading the above article some years ago I always lightly grease the square faces of the spindle. Never seem to be able to find my copper-slip so I always use my regular Finishline teflon grease.
Rhythm Thief
Ross on Wye
This issue divides cyclists in the same way helmets do.:biggrin: I smear taper axles lightly with grease before assembly. As did George Longstaff, who knew a thing or two about bikes.
ianrauk
Tattooed Beat Messiah
Rides Ti2
Another one here who uses a small amount of grease. Always have done.. but for life of me can't remember when I started or why.
barongreenback
Warwickshire
Just bought a Shimano bottom bracket and the square taper spindles are pre greased.
guitarpete247
Just about surviving
Leicestershire
Always use copperslip but will now start to use threadlock especially on the left crank. I always replace the dust caps glad I do but have never had a nut come loose so far. :rolleyes:
