Crank arm bolts too tight?
TheDoctor
The TerrorVortex
What, if you grease it? Or if you ride with the crank loose?
Doesn't matter, as it's the softer component in either case - the crank.
B
bigfella
Essex
I mean if it really has been over tightened.
TheDoctor
The TerrorVortex
Oh. That'll be the crank too. It'll get forced further down the crank than usual. Probably.
Seriously, if it all works and the cranks aren't bashing the chainstays it's probably fine.
