lucklesspedestrian
- Perth (ish)
1) When I got the bike (Forme Longcliffe 3.0 road bike) delivered (boxed up from Rutland Cycles) I got the son of a work colleague who works in a bike shop to build it up.
I was wee bit surprised on my 2nd run to notice the chain rubbing against the front derailleur (shimano tiagra, 2x10) so I followed instructions on a few 'how to' vids but still no joy. I then took the bike into my my LBS and was surprised when he told me that this was normal e.g. when on the largest of the 2 front rings and getting down to the small cogs on the rear cassette. He took the bike anyway, adjusted the gears and did a few other little jobs, only charged £12 and gave me the bike back.
Went out for a spin this evening and sure enough, the chain still rubs a bit on the derailleur once I hit the 5 smallest cogs on the cassette if I'm on the big front ring (which I'm quite pleased to say I seem to do quite often!!!).
So my question is....is the LBS guy right, is this normal?
2) My front brake makes a helluva noise when I apply it. Again, I mentioned this to the LBS and the chap said he could see some debris in the pads and would sort it, but again, when I took the bike out this evening it was really noisy. (rear is not exactly quiet either!) Are there any super- duper replacement pads I might purchase? (I've got Mavic CXP 22 rims and Forme alloy dual pivot 47- 57 mm cartridge pads).
3) sorry to go on....!
I really miss not having brakes to hand like on the flat bars and having to either drop down or my hands can just about get some leverage but not full power if I'm riding with my thumb and forefinger either side of the brake/gear mounts. Does anyone know if microshift brakes can be retro-fitted with those extra levers which you can just pull in from the tops?
I'll leave it there (for now!)
Thanks
Steve
Thanks
Steve
