BABCP, BPS, NHS, GMC registered therapist with additional specialist training and experience , NMC (RMN only) registered therapist with additional specialist training and experience.What would you suggest then?![]()
Yes you can self refer to some CMHTs but the criteria is so high due to cutbacks within the NHS, loss of third party partners, lack of qualified and experienced staff, and most recently the agency fee cappings.Can you still ask for a referral to a CPN?
No, it's a pay a fee and join with minimum requirements. Only the BABCP accreditation is now asked for by the NHS. Counselling is not a thoroughly RCTed evidence based practice. That's why there are so many pcc's looking for work.BACP is the leading organisation for counselling in the UK. It is recognised nationally and internationally, and is working with other organisations such as UKCP and the BPS, on statutory regulation. Holding a BACP accredited qualification used to be the NHS minimum requirement for employment before the Government decided to water down the requirements with the introduction of the IAPT programme, which primarily uses people with low level qualifications.
People with low level qualifications?! You've clearly no idea wtf your talking about.BACP is the leading organisation for counselling in the UK. It is recognised nationally and internationally, and is working with other organisations such as UKCP and the BPS, on statutory regulation. Holding a BACP accredited qualification used to be the NHS minimum requirement for employment before the Government decided to water down the requirements with the introduction of the IAPT programme, which primarily uses people with low level qualifications.
Quite clearly your 'area' is different to the rest of the IAPT model who don't use counsellors.......the model uses Psychotherapies not counselling. And the LI's are still higher qualified than most private 'counsellors' HI's are MSc minimum Psychotherapists using evidence based robust psychotherapy models as per the IAPT model.Oh really? I used to commission IAPT services. I was also one of the people involved in delaying rollout on several schemes as we could not be satisfied about the quality of training provided by two universities.
Commissioning services doesn't necessarily mean you know your field, which based on your outdated beliefs, I don't believe you do.Oh really? I used to commission IAPT services. I was also one of the people involved in delaying rollout on several schemes as we could not be satisfied about the quality of training provided by two universities.
So only one job for counsellor? And why only Band 6 if they're so valuable? When HiTs are Band 7? Out of all those trusts you quoted? Hmmm, point made I think.Look on NHS jobs. Ooh - here's one: IAPT Counsellor. And here's the person spec.
Plenty more where that came from...
Oh, by the way, before I joined the NHS I worked in healthcare regulation. One of the areas I worked in was psychotherapy. Even when I joined the NHS I remained a consultant with one of the major national psychotherapy bodies, only giving it up in 2014 when I started my current job.
I also was involved with the work that has led to the Professional Standards Authority. For all your puffing of the BABCP, I think you'll find it is not an accredited register - unlike BACP.
And again, go and look at the accreditation process for both, read them properly and map across skills and qualifications required. Once you've done that, then please come back to me and try to tell me that the BACP accreditation qualifications are high without laughing.Look on NHS jobs. Ooh - here's one: IAPT Counsellor. And here's the person spec.
A quick search for BACP accredited counsellors shows the low levels required:Look on NHS jobs. Ooh - here's one: IAPT Counsellor. And here's the person spec.
