cotter pins
tyred
Ireland
I bent the cotter pins hammering them out of my Elswick-Hopper Cosmopolitan 🙁. Also worth stating that they should really be pressed in as well, rather than just tightening the nut to pull them in.
I think this is where people go wrong. If you only tighten the nut they will bend and come loose very quickly.
Pressed or hammered into position properly and they won't give any problems in service.
Chris S
Birmingham
Raleigh were still using them in the mid 80's on the 3 speeds
They're still used on South Asian bikes. I'd be extremely surprised if the Flying Pigeon didn't use them as well.
tyred
Ireland
The other thing is that a lot of people don't use a hammer properly. If doing something like driving out a pin, you need to hold the hammer at the end of the shaft and hit it hard, deliberate blows. The shock will help free it.
If you just sit tip-tapping it you will be more likely to just rivet the thing in place.
Dogtrousers
Lefty tighty. Get it righty.
Here's what the late Richard Ballantyne had to say on the subject. From "Richard's Bicycle Book"
rrarider
Liverpool
I was about to mention the same thing as @Dogtrousers , when his post appeared. I've done this to get the pins out of my Raleigh shopper, prior to servicing its BB. I then realised that Raleigh BB threads are peculiar to them. As it only ever goes 2 miles to the shops, I can live with a slight clicking noise.
Horrible things, I wouldn't touch one.
They are a pain and luckily most people these days will never have to deal with them. I often work on very old bikes with cottered cranks and we try to keep them period correct if we can.
Hard work but very satisfying when finished. Occasionally we have to swap them for a square taper but only once have we had to resort to an angle grinder.
