Coping with wind!
Supersuperleeds
Leicester
What wind speeds are acceptable for cycling without spoiling the ride - for example the forecast for my area tomorrow winds between 6 to 9mph would this be ideal for a ride? I tend to avoid cycling in winter but I want to maintain some fitness and miss getting out; a gym room is just not the same.
Sometime the lower winds speeds are worse as you get it against you in every direction, you are either biking against it or through it. At least with a wind faster than your cycling speed you will have it pushing you along at some point
Dismount
Yorkshire
Cheers if I do go out tomorrow I will update this post with how it went
