bikingdad90
Not a lot of difference in the width so both will be cross compatible, the 1x version will however be shorted in links as it doesn’t need to wrap around both the mech and front cogs, there is just one cog.
Yes, should do. 11 speed is 11 speed.
What type of crankset are you going for?
A narrow wide one will help keep the chain engaged, whereas a double chainset could cause the chain to come off due to the profiling for the small cog shift and may need a chain guide to keep it on.
@vickster , what you've proposed with a 42 chainring and 11-42 cassette will be fine. Your lowest gear will be the same as a (50)/34 chainring and a 11-34 cassette, your highest will be about the same as your second (or third) highest at present. You might "spin out" at earlier at maximum speed, or your cadence range will grow to compensate.
11 speed chain will be fine for either, just make sure it is cut to the correct length for your new drivetrain. Lots of guides on YouTube if needed.
See post #6. An unclaimed TMN to me. (and the chain length is the same (see ^ ^))Finally a straight answer - a comparison plus the effect of the change.![]()
I don’t ride in a club, never have, never will![]()
