I've had an SRAM iMotion9 hybrid bike for about 12 years and would appreciate advice on how to select a suitable replacement crankset.
After cycling the SRAM iMotion9 bike, I now often suffer from knee ache (started to happen over the last few years). Depending on several factors, knee ache can occur after just a few miles of cycling. Very frustrating and very limiting. I also have a GT Tequesta ATB which doesn't give me knee problems (although, these days, I rarely cycle more than 25 miles in one stint). Over the months, I've tried to asess why the iMotion9 should give me this problem whereas the GT ATB doesn't. My theory is it's the Q factor. The iMotion9 seems to have a very high Q factor whereas the GT ATB Q factor is siginificantly lower so I wish to replace the original SRAM crankset with a lower Q factor version.
Having looked into this today, I can see it's a potential minefield and would appreciate any advice or guidance on how best to go about this. Seems to me that most online sellers don't mention the Q factor of the cranksets they sell. I wish to spend as little as possible on any replacement. So far, I've identified 6 parameters that need to be met:
The replacement must have:
1 Low Q value. Unsure exactly what? Will try to measure GT ATB Q factor.
2 Crank length 170mm
3 Fitment to suit SRAM "splined" bottom bracket crankshaft (or maybe change BB for more conventional "square peg" style fitment - is that even possible?)
4 42 tooth chainring (40 or 44 would probably be OK too)
5 Accomodate a 1/2” X 3/32” single-speed chain
6 And, of course, the new chainring needs to line up with the single rear sproket - how do I ensure that prior to purchase?
Have I missed anything? Grateful for any help, thanks.
