Cones coming loose
Hawk
I'm now familiar with cone and cup adjustment.
However, my cones seem to be coming loose every 70-100 miles (more than once a week) which costs me a fair bit of maintenance time.
Anybody kind enough to share any tips about how to stop them coming apart so easily?
Cheers
mr Mag00
rising member
Deepest Dorset
threadlock and tension on the locking nut
To lock the cones requires a little bit of skill.
The locknut is tightened right up up to the cone, then you get a cone spanner on both the lock nut and cone.
You can then lock them in position by simultaneously tightening the locknut and unscrewing the cone into the lock nut.
Give it a try - to achieve a solid lock requires quite a bit of force.
The skill is that you have undone the cone slightly in doing all this and the axle will be slightly loose. So you need to compensate by overtightening the cone in the first place.
Have a go - it does require a bit of practice to master the art though.
Manonabike
Yeap that is the way I do it too..... I would also add that you must allow a little bit for the QR skewer if you use one, otherwise you might end up with a cone to tight
H
Hawk
Yup, I use my 17mm spanner on my locknut and my 15mm cone wrench to counterrotate the two and lock them together.
Any chance of breaking anything if I put all my weight on it?
Manonabike
I don't think that is necessary though.
Cone's wrench are very thin and if you don't have a good one then you might damage the cone using too much force.
tyred
Ireland
If you have non-quick release wheels, the easiest way is to tighten the axle nut on one side to lock that side to the drop out and then make adjustments on the other side.
actonblue
You should be able to adjust the cones without having to resort to using thread lock.
Have you checked that the cup and cone are not damaged or worn? if they are this will prevent you from making proper adjustment.
