ThanksI believe it's just called a nut (not a cone).
They always have ridges which helps it bind and stay tight.
I'd guess that the grinding noise you are hearing is simply the ridges bedding in as you tighten it.
Nothing to worry about.
Any good bike shop or you can run without them if needs be.Absolutely. If I had to get spare springs, where would I get them?
By hand, and not too tight.Thanks
I usually tighten it by hand - should I be using a tool of some kind? That's the crux of the matter!
Thanks
Bike shop...or a new skewerAbsolutely. If I had to get spare springs, where would I get them?
No. You need to be able to close the QR skewer (oh and get it open again) so unless you're Superman or the Incredible Hulk, just do by hand!Thanks
