The English language is full of expressions that are logically fallacious, but nevertheless understood by practically everyone.
Does it really matter for this conversation?Either they are both doubles, or they aren't.
Rant on.While we are being pedantic .... Compact Chainset please, not Compact Crank. Crank (or crank-arm if you're from the USA) refers to the long straight part to which the pedal is attached, not the whole assembly of cranks,(spider) and chain-rings. All chainsets I've ever known are double crank.Rant over!
Back when there were only 6 speed blocks? How are your knees?I'm old enough to remember when a standard double was 52/42, and 42 was the smallest ring which would fit on the spider!!!!!
A compact double 50/34 is referred to as a compact. A semi-compact double 52/36 is referred to as a semi-compact. A standard double 53/39 is referred to as a double as it was once the only double there was and, therefore, no need to specify what type of double.
Simple enough really.
Back when there were only 5 speed blocks, and knackered, respectively!Back when there were only 6 speed blocks? How are your knees?
It is a myth that high gearing damages the knees. If the gear you are using is too high your thighs will refuse to push the pedals round long before your knees give up. Walking up stairs - which most of us do many times a day - puts far more strain on the knees than riding a bike where your body weight is supported. Runners, footballers, rugby players and dancers put far more strain on the knees and all the other joints than cyclists do and they seem to manage ok. All my racing was done in the days when 42x23 was the lowest you got and my knees are ok.Back when there were only 6 speed blocks? How are your knees?
