GrasB said:Is it or are you just assuming everyone has your riding style?
I'm not assuming anything just answering the OP with my experience.
The OP tells us he runs 52/39/28 and 99% of the time never uses the 28. So, his riding style is almost exclusively 52/39 which is more standard double than anything else. He must generally climb on the 39 ring which i'd imagine sees a lot of use in his riding style. So he might miss it when it's gone. A 36 might be OK but possibly not low enough when he needs that granny gear, so may need a 12-27 cassette which does not give a smooth transition (which he already has).
If he goes for a compact i'll bet he'll spend a lot of time in the 50 in the big/big combos.
How will a compact help him? That was the question.
IMO compact's are a compromise developed in Europe to give a triple ratio over two chainrings. The advantage being that it's still a double and saves a few grams over a triple. To some cyclists there is still the notion that triples are for wimps and real cyclists only need two rings.
However, i myself use this obvious compromise and with a bit of tweaking manage to work with it OK
