Cold Weather Riding (outside)
12boy
Casper WY USA
Wool and wool blends good. Crosscountry ski pants over bike shorts and merino- poly longjohns great for legs since rain and snow bead up on the outside. Balaclavas good, too. I wear $3 wool liner gloves under 240 gram thinsulate gloves or mittens. I also like windblock fleece over a couple layers since i found one in red. HiVis good in sketchy vision situations..
mudsticks
Obviously an Aubergine
A lightweight windshirt is invaluable as an extra layer imo.
Easy on and off, cuts the wind, and weighs close to zero.
Thin plastic gloves under standard cycling gloves, as a windstopper
Waterproof socks.. Even if its not wet, they add warmth.
And take one of those iron filing tea bag, hand warmer type things as a back up..
I rarely use it, but it's nice to know its on board if you get chilled.. Once it's activated, then tucking it down your front can make you feel a whole lot warmer
Merino baselayers . I find synthetic get stinky within 5 mins.. If I smell bad to me, then I don't want to impose that on an overheated cafe..
PeteXXX
Photo Winner
Hamtun
Keep the fingers and toes warm! For me, in the words of Iron Maiden, 'Nothing else matters',
Apart from a windproof skull cap :okay:
LeetleGreyCells
Un rouleur infatigable
A tip for warm, dry feet if you don’t want to buy cycling-specific winter socks is to wear a thin pair of socks, add a food/freezer bag over the socks and then a second pair of socks over the top again. The three layers traps air keeping your feet warm and the bag keeps them dry.
It’s a useful trick for the coldest and wettest of days though in warmer winter weather your feet could sweat defeating the purpose.
Unfortunately, most clothing choices are trial and error until your find what works best for you.
As all above, doesn't have to be cycling specific, layers, wear what you have or what you can afford. A pair of clear lens glasses help a lot too, no fun riding in a cold wind when your eyes are streaming.
Sharky
Kent
As most have said, layers, with the outer layer windproof and close fitting etc.
But since a spill on black ice in 2017, resulting in a fractured pelvis, I now give it a miss when it is frosty, rather than ruin the whole year.
Always another day.
mudsticks
Always another day.
Yes I had a moment of madness a few years back, thinking cycling on snowy roads, but staying in the tyre tracks would be OK - with standard hybrid tyres. Dohh
Didn't manage to break myself quite as badly at that, but I don't think my knee has ever truly forgiven me .
Sometimes - not riding is the best option.
Technical/merino base layer and a windproof softshell jacket - that's all you need. I have varying thickness jackets for the temp, but only have the two layers on. Summer it's a base layer and a short sleeve top - again two layers.
Deleted member 1258
I use a bamboo base layer, basically a bamboo t shirt, an old sweat shirt, one I brought years ago when I was working outside a lot, with a cycle jacket on top, and if its really cold I'll add a scarf under the cycle jacket. For gloves I buy the pound woolly gloves from the Coventry Market which are warm enough for me unless its really cold, when that happens I have a pair of thermal gloves from the market which I wear. On my feet just a pair of normal socks, cycle shoes and overshoes are warm enough.
Joffey
Big Dosser
Yorkshire
Layers are great yes, but if you feel like you have too many clothes on you could always purchase a top end jacket. I have a Castelli Alpha Jersey and you can get away with most low temperatures with just a mesh base underneath. You can pick them up for around £120 on Wiggle last time I checked.
Non cycling clothing is often better in v cold conditions. Layering up rear pockets can get uncomfortable and they are not usable.
Jersies with a high zipped neck are good.
With a decent base and windproof outer layer you can fill midlayers with anything. I like a few thin woollen sweaters.
If I am doing big hills on a cold day I often remove a sweaty base layer at the top, pref replace with dry one.
My test for winter windproof is the Huff Test. Try and huff some breath through the material. If it goes through with little resistance it is for mild weather use. If you cant huff through at all it will be too clammy. You can use two thin windproofs to good effect.
Winter footwear should be larger size and without ventilation.
Clipless pedal cleats are a metal heat sinks inside your shoes. Insulate with eg cork insoles.
Wool socks are recommended. My sock of choice are Norwegian army wool ones, purchased from the Salvation Army in Stavanger. I don't think they are standard issue to the Norwegian Salvation Army but the regular Non-Salvation Army know their socks.
