What, so CNC machining isn't being cheapskate now then? Its the done thing?
I'm not quite sure what your question is but I'll explain my stance on "cheapskate".
Hubs can be forged or CNC'd and most people won't know the difference and I suppose it doesn't really matter in the greater scheme of things. However, forging is better because it makes the hub shell strong. Why stronger? I hear you ask. Shurely strong enough is strong enough. Well, if it is stronger, you have less warrantee problems and, you can create better wheels using higher spoke tension. But most of all, you can make the hub lighter and beautifuller, with elegant thin flanges and wonderful smooth curves.
CNC hubs are more expensive to make per item but cheaper to tool up the factory. Therefore, under certain volume they go for CNC and over the economic threshold, forging.
Horses for courses.
