Is there anywhere I can try clip pedals on my bike before I buy them? One of my ankles is not quite as flexible as it should be so I don't want to spend £££ to find my ankle screams every time I try to twist it out. Would like a way of trying some on an indoor trainer/a bike like mine just to see if it's comfortable...
Have you got a cyclist friend who might be able to let you have a go with their clipless pedals? I've personally never heard of a shop doing "try before you buy", but that's not to say they don't exist.
In all honesty a fairly decent "beginner" combination of pedals and shoes can be purchased quite cheaply. Bought a set up for my son at
Wiggle last year, Shimano pedals were £16.99 and the DHB shoes were about £35. Both still working perfectly. I've done no maintenance on the pedals and they still run as smoothly as ever.
Most pedals have some system whereby you can adjust the release tension. My own pedals hold the shoe securely, but don't need massive force to disengage. I have always made sure I bought pedals with a small amount of "float" which allows a degree of side to side movement. This is because I have had slight issues with my knees in the past and didn't want to put them under stress by having my feet/legs locked in one rigid position throughout the pedal stroke. All I have to do is twist my heel out about 7 degrees and it disengages.
Fair to say they can take some getting used to, and you'd be wise to sit in your garden, holding on to a wall or rail, practicing clipping in and disengaging quite a few times before even thinking about going out on the road.
One of the best upgrades you can make, and one that will most likely improve your cycling considerably.
Give it a try.......and let us know how you get on if you can!
