Climbing technique
Joshua Plumtree
Approaching perfection from a distance.
I find the secret to hill climbing is to get faster on the flat!
Once you've reached a certain level of fitness it's then much easier (comparatively!) to spin up most hills. Seated in a low gear, under geared initially - the complete opposite of what was recommended in that cycling article - and keep the cadence high as the gradient increases.
Head and body as still as possible. No rocking. Again this is easier if you're spinning fast in a low gear and not having to apply too much force/weight/pressure through the pedals.:rolleyes:
Only time I would get out of the saddle would be close to the summit and only then if I've misjudged the steepness of the hill and my cadence has dropped too low.
nappadang
Gateshead
I like to remain in the saddle on long climbs though I often try to sit more upright once in a while to change riding position. Throwback from mountain biking. I climbed hills better on the bar ends which always made me feel I was sitting more upright.
Boon 51
Deal. Kent.
I find climbing easy but then I don't weight sod all, but I have found on most hills its the bends that are steeper so a good trick is to sit on the straights and stand on the bends..
nickyboy
Norven Mankey
2-3 minute maximum effort climbs I'll do out of the saddle. Also if I'm in a bit too high a gear on a shortish upslope I'll get out of the saddle to make it more comfortable. Otherwise I'll climb seated. On long climbs (20 minutes plus) I'll probably do a few seconds out of the saddle every now and then to vary my posture
Dogtrousers
Lefty tighty. Get it righty.
I really like standing on the pedals on uphill hairpin bends. I can pretend I'm going up the Alpe d'Huez. From an extremely long distance I can be mistaken for Alberto Contador's much larger, much older brother.
So the heavier you are the more power you can put out?
I would normally answer with something witty, but there has already been so much utter tosh said on this thread that I am struggling to come up with anything sufficiently funny. Carry on, at least it is entertaining.
