SWSteve
- Bristol...ish
Is there anything I should know to avoid re: chain tools? Don't have a clue about what to get/avoid as haven't ever bought one before.
Dude. Read the thread.is it necessary to purchase a chain cleaner? are they worth investing in or do they not make much of a difference?
I did ...............thus the question something like this maybe? http://www.amazon.co.uk/dp/B000BS02...d=17641815511721976189&hvpone=&hvptwo=&hvqmt=
pardon?If the cassette is really bad take it off, bottle of white spirit and an old brush (can be done in situate but easier when it's off. Same for the chain if it's really bad, then re lube.
Edit you can also split the cassette by removing the pins and clean individual cogs (and change ratios with different ones if you want)
I 'mickled' a chain with a weeks worth of crud on it yesterday, which got a lot of the crud off . I then used a Lidl chain cleaner on it (using citrus degreaser) and it removed a lot of extra crud missed by 'mickling'. So yes IMO they do make big difference, but it all depends what you're wanting to do. It's not necessary to have one but they are useful if you do - but I only ever use it with the chain off the bikeis it necessary to purchase a chain cleaner? are they worth investing in or do they not make much of a difference?
I use the oil and rag wipe method for frequent day to day lubing/cleaning, but it's never gonna get all the crud off (assuming that what your after)
Which bit didn't you understand, cleaning the cassette with a brush and white spirit like wise the chain, this can be done with the chain and cassette on or off the bike, or removing the pins/rivets to clean the cogs individually, or changing individual gears for others.pardon?
Just looking at some videos on youtube of it now seems easy enough i know what my day off is going to involve nowDon't bother removing the cassette. Just take the wheel off, get a strip of old towel (a couple of inches wide), give id a squirt of GT85 and 'floss' in between the cogs. Takes 5 mins to get it looking like new
Takes me about that long to take the cassette off and clean and put it back on, but everyone has there own methods.Don't bother removing the cassette. Just take the wheel off, get a strip of old towel (a couple of inches wide), give id a squirt of GT85 and 'floss' in between the cogs. Takes 5 mins to get it looking like new
brush, white spirit and chain are bits I understand. The rest is alchemy and weirdWhich bit didn't you understand, cleaning the cassette with a brush and white spirit like wise the chain, this can be done with the chain and cassette on or off the bike, or removing the pins/rivets to clean the cogs individually, or changing individual gears for others.
