iluvmybike
Check it for wear before u do all that - might need a new one!
True, it can soften the cack.Not necessarily.
A fresh coat of oil/lube can help lift off caked on gunk. Keep running the chain through a rag and it soon clears the mess.
I usually get a good two weeks between wiping down and relubing the chain. I'm using a wet lube again now as the weather is changeable, which picks up dirt a bit more, but I just give it an occaisional wipe mid-week. Chains seem to last a reasonable length of time.Have read this with interest, esp the "don't clean it merely rub it wiv a cloth" technique". I'll give that a go.
My technique is to undo the magic link and immerse the chain in bike cleaning stuff from eBay, some sort of citric thingy, then wipe and add some dry lube. This lasts for a few days and while on tour the best trick, IMHO, is to let it develop an annoying squeak until someone else in your group gives you some of their lube.
Not necessarily.
I plan on getting rid of excess dirt and crap off of it, but running it through an old rag, then applying new oil, as the Mickle Method states (from what I understood) that the only part that needs oiling is inside of the chain and not the outside.
One drop of oil of each roller of the chain, apply to the top of the bottom section of chain if you see what I mean, run the peddles backwards a good few times to let the oil flow into the links, leave a while, spin the peddles a few more times and then wipe the chain down well with a rag. That's all I do and you know I like a silent bike.
