So when i am in the outer cog in front and the smallest cog in rear i realized that my chain is rubbing. I tried to screw it all the way in and out but as you can see in picture#1 it doesn't touch so it doesn't work. When i pull the derailleur with my hand it doesn't touch to the chain anymore but bc of the spring it just comes back and rubs again once i leave it .
I believe that the problem is there is some kinda middle shifting position in between normal positions. And again as you can see in picture #2 the red thing looks like it is in middle and if i put more pressure into the lever it goes until the end and it brings the derailleur to a position that it doesn't rub anymore when i leave the lever it comes back to middle.
(i couldn't upload the images to here directly)
picture #1 =
View: https://imgur.com/a/skfQCGB
picture #2 =
View: https://imgur.com/a/Z8Cm1ZG
picture #1 =
picture #2 =
Unclamp the cable. unscrew the H upper limit screw a few turns. Can you push the cage over to beyond where it needs to go by hand? If so, the issue is lack of cable tension when in the small chainring.
