Choosing a bottom bracket
4F
Suffolk.
I have recently converted my old 1970's Dawes to fixed running off the smaller front double chainset and decided that I like it but need to up the chainset size as the 40 ring is just too small. It's not a spider so I cannot change the ring so I have just puchased this RPM chainset that has come off a Fuji Track Bike. 48 tooth 1/8th single ring PCD - 130 170 length cranks
Never having replaced a BB before what measurements do I need to look for to make sure I get the right one ?? I have measured across the outside of the BB and come to 6.8 cms.
Thanks
e-rider
Banned member
South West
Yes the BB shell is usually 68 or 73 - you have measured yours at 68 - this is the most common size and are available from all shops.
Is it a square taper or ISIS axle?
Now you just need to get the correct length axle - this is not so easy.
If it's a single ring chainset you'll need a fairly short axle to get a decent chainline but it depends on a few things. Trial and error is the usual approach. I'd guess at about 107mm or maybe a little shorter.
See what other posts you get!
4F
4F
Suffolk.
It's a square taper and I am assuming English as all the original components were non Italian ie sachs huret mech and weinman brakes.
No idea what a JIS standard is ??? (OK just looked this up on sheldon)
PpPete
Chandler's Ford
tundragumski said:
oh yeah, you might want to check the thread but it's probably english
If 68 mm shell it's definitely English thread.
I have no idea how you check whether a square taper on a crank or axle is JIS or ISO standard.
I would guess that a chainset off a Fuji would want a JIS taper.
One approach would be to pick up the cheapest nastiest Shimano compatible BB you can find on fleabay (I got one for 99p once!)
Pop that in - and see how far out your chainline is, deduct or add miilimetres accordingly then replace with a decent BB of whatever length you arrive at.
4F
4F
Suffolk.
My current BB is square taper so I suppose by offering up the new chainset I should be able to deduce if it is JIS or not and then try and measure from this how far I am out with regards to axle length. I assume a JIS will not fit onto a standard square taper ?
jpembroke
Cheltenham
Bound to be JIS isn't it? JIS is Shimano (and most other makes). ISO is Campag. Your good 'ol Shimano square taper UN53/54 is JIS.
Landslide
Rare Migrant
JIS is a standard square taper, as is Campy's ISO. They're just slightly different standards.
FWIW, I've run a Campy chainset on a Shimano BB (ooh, the heresy!!!) without any problems, but I know some people have had issues.
Have you tried (loosely) fitting the new chainset on your current BB axle? You may find that it sits there quite happily, giving you a usable chainline.
4F
4F
Suffolk.
aaah OK thanks learning more and more as I go along, not got the chainset yet so will await its arrival and offer it up and see where I am at.
jpembroke
Cheltenham
I built a fixie for a mate using an RPM chainset. It did need a JIS bottom bracket. I think I used a 110mm UN54, which cost about £15.
NickM
One thing to be aware of: Shimano 110mm and 107mm BBs both have the same drive side overhang - the NON-DRIVE SIDE is 3mm shorter on the 107mm BB.
So you just select whichever of 107 and 110 gives reasonably symmetrical crank/chainstay clearance.
Next (Shimano) size up is a 113 - and just for kicks, the difference between 110mm and 113mm is 3mm all on the DRIVE SIDE xx(
jpembroke
Cheltenham
Next (Shimano) size up is a 113 - and just for kicks, the difference between 110mm and 113mm is 3mm all on the DRIVE SIDE :angry:
Cool! I didn't know that.
Gold star.
dudi
Ipswich, Suffolk
FFFF, I've got a 110mm one and i'm a little out on the chainline.
If you can ge a slightly shorter one, then go for that... but by the sounds of it, a 107mm one own't help much
