A beep is fine. I'm not a hardcore cyclist. Just looking to easily follow a route
Thanks. Like the idea of a phone battery but I'm guessing the cost of a mount plus the battery will work out the same price ?
Get £7.50 off if BC member and don’t forget quidco
wow. at 51p delivered those straps are worth a try. I cannot quite see how they work though? they seem to fix round the bars then provide two loops,,,,Nope. £25 all in.
https://www.amazon.co.uk/dp/B019GJLER8/ref=cm_sw_r_cp_apa_O46jAbAT62FHW
https://www.amazon.co.uk/dp/B00EDI6I5Q/ref=cm_sw_r_cp_apa_e36jAbKRMP86N
I've used the straps myself with my own smartphone. It wiggled a bit but otherwise perfectly secure.
Edit: The obvious issue with this would be waterproofing. Cling film maybe?
Put strap on bars, hold object on strap, pull the back loop under bar and stretch over the front of the object (which is above the front loop), pull the front loop under bar and stretch over the back of the object.wow. at 51p delivered those straps are worth a try. I cannot quite see how they work though? they seem to fix round the bars then provide two loops,,,,
