Cheap folding bike that won't fall apart with an 18st bloke sat on top of it?
simon.r
Person
Nottingham
A Pashley Roadster would fit your requirements I reckon.
Coincidentally I've got one for sale (at least I will have as soon as I clean and fettle it):okay: You won't get much more sit up and beg and it will certainly take your weight!
If you're interested and somewhere near Nottingham give me a shout.
Edit - Just re-read the thread and I have to concede that this isn't a bike you'd want to take in a lift. Reasonably unattractive to thieves though if you leave it outside, I'd think.
Spinney
Bimbleur extraordinaire
Back up north
The b-fold 320 looks good but says 100Kgs which is about 15 stone - would I be taking a risk riding it or do you think it would cope with the bit of extra okay?
I think it might depend on where you are riding it. If you are on smooth roads with no pot-holes, and never, ever try riding up or down kerbs, you may well be OK. There will be a margin for error in that max weight, to allow for sudden shock loading like bumping into pot holes etc. If it was a civil aircraft, it would be strong enough to cope with 1.5 times the maximum load the engineers think it would ever encounter.*
(At least, I assume so - it should be the case!)
And if you spend less time :addict: and :cheers: and :popcorn: starting now, you may be a little less than 18st when you get it...
:okay:
*and we know that aircraft never, ever break!
biggs682
Northamptonshire
Globalti
......and when you get to work, swop that giant coffee for a small expresso with no sugar and get the same caffeine hit for almost zero calories.
Bimble
Bimble
Bimbling along ...
Thanks guys - really helpful - and liking the look of the Raleigh Stowaway 7 too. Googling it seems it has a max rider weight of 105Kgs, which I should be able to get down to with a bit of willpower on my diet and a few months of cycling.
The roads and cycle paths to work are all fairly smooth and have dropped kurbs so hopefully the bike won't take a massive pounding, and if I let a bit of air out of the tyres it should soften the ride to make it more comfortable whilst I get used to it.
Bimble
Bimble
Bimbling along ...
Be careful letting down the tyres. Make sure the rim doesn't bottom out if you misjudge a bump.
Thanks. Just had a thought - if I bought one online would it need any "putting together" when it arrived?
[QUOTE 4149545, member: 45"]You think? I don't. Most of the bombers around here are on gas+pipe Asda full-sus MTBs.
As a reliable, sturdy commuter the Subway is excellent. It's not overly heavy, and weight isn't an issue in these circumstances. More important are comfort and gearing.[/QUOTE]
He said in post 9 he needs to carry the bike upstairs. I couldn't carry a full size 16kg bike upstairs myself
[QUOTE 4149655, member: 45"]I've never had a problem carrying bikes up stairs, even with luggage on. The weight isn't the issue. I find the length of the bike and tendency of the fork to swing more of a problem bit that can be overcome with a bit of practise.[/QUOTE]
Good for you :smile: I'm awaiting surgery on an unstable shoulder, not wise to carry big weights
And I'm not very strong anyhow!
