cyberknight
- Land of confusion
Yes carbon post , fabric scoop saddle , superstar elite 24 wheelset and upgraded brake clipers to tiagraThanks for the heads-up
I've since done a bit more homework and it seems that the VO item changed in format some years ago from the original two-bolt with cylindrical nuts that allow you to adjust saddle attitude independently of fore-aft position to what I've seen referred to as the "hocky stick" setup where one affects the other.. which is a shame.
Tempted to try and find an early VO item but apparently they were subject to a recall due to the clamping plates cracking; which is perhaps why the design changed (although a couple of years seems to separate the recall and design change).
I'm also put off a little by the short length after having a frame killed by a post (well, shim) with a short amount of contact inside the frame. It's proving really bloody difficult to find a decent seatpost with a genuine, significant amount of layback and a decent adjustment mechanism.
It's interesting that you feel the need to move yourself back because of short legs, since my driver is long legs - perhaps there's some shared issue with thigh length or something.
You certainly have a (for me) terrifying amount of reach on that bike! Weren't out on it earlier around Oxford were you? I vaguely recall seeing someone on something of similar colours, but it escapes me as to where it was now..
Thanks - shape looks good; how are you finding it?
A fine choice of steed too - is that an aftermarket seatpost?
EDIT
changed the stem too as the stock bars have a very short reach so i had to add 20 mm to the stem to get the same reach as my winter bike
