Mr Pig
- North Lanarkshire
Dave5N said:If they are screwed in right I don't see how they will move beyond the tolerance in the thread.
The thread doesn't define the absolute position of the end cap.
Think of it as a bolt. Say you screw a bolt onto a threaded hole in a block of steel. Now imagine that the face of the block is not square, not at ninety degrees to the hole, but is slightly off. The bolt will zip into the hole until the head of the bolt contacts the top of the block. Obviously the head of the bolt will not be flush onto the block, it will be touching on one side but not the other. What happens next depends on the strength and configuration of the two parts.
As you tighten the bolt further what will typically happen is that the shank of the bolt will bend as the threads pull on the head, allowing the head of the bolt to sit flush on the surface. Obviously this will weaken the bolt and if the shank bends enough, is put under enough stress, it might fail immediately.
This is what I can see happening in a Hollowtech bearing. The bearings are effectively mounted in the head of the bolt so could end up pulled off of true to the threads/frame. As I say, I've not used a Hollowtech bearing but I've seen this often enough in other, similar assemblies to know it happens.
