Changing from 11-28 to either 11-32 or 11-34 cassette...
Dogtrousers
Kilometre nibbler
Everyone has said all the stuff I would have said (SS vs GS, capacity, chain length blah blah)
But good luck with it. Go for the 34!!
albion
Not much of a jump really. Why not 11-40T with a long cage derailleur?
10 speed being mtb compatible you can buy both very cheap.
My switch to a single chainwheel 11 speed setup was 11-50T.
roubaixtuesday
self serving virtue signaller
albion
'Special'.
Hmmm.
'There is almost no interchangeability between the 4700 series and the 4600 series, but for sprockets, there is no such thing as a 4700 series sprocket, and the CS-4600, CS-5700, and CS-6700 can be used with both the TIAGRA 4600 series and TIAGRA 4700 series.'
roubaixtuesday
State of those cassettes.
The "after" photo to restore your calm somewhat
A good clean up - 5 watts saved. Must be equivalent to an extra 2 teeth on the cassette for starters.
Definately.
Mazz
Mazz
Leicester
Should I change the rear gear cable while I'm at it?
It's not been changed after at least 6 years of daily use.
Dogtrousers
Kilometre nibbler
Should change the rear gear cable while I'm at it?
I would. Not for any scientific reason. Just because- as you say - you may as well while you're at it. It will only make the job marginally more tiresome, and it gets the task out of the way.
si_c
Wirral
Excuse my ignorance. What do you mean by housing? Is that the cable outer?
Yes, the inner cable will inevitable pull some dirt, debris and water into the housing as it's used - replacing both the inner and outer part periodically will make shifting much smoother and give it a lighter action.
