One has a slightly lower gear but a couple of changes with a bigger ratio difference. FWIW I'd say if you're going to change at all you might as well go for the bigger change.
You need to check if your current derailleur can cope, both (1) maximum cog size and (2) capacity. It's imperative to make sure your chain is long enough to cope with big/big - if not it'll tear your drive chain apart if you inadvertently select it.
Cheers, to answer your question, current derailleur is Shimano Tiagra. And yes I had to wipe the crud off it to reveal the name.
P.s. I don't know what you mean by capacity. If you mean the number of rings, the old and new will both be 10 speed.
P.p.s. this is for a road bike Allez with a compact chainset, if it makes a difference
Thank for the explanation.Capacity = (Difference in front chainrings) + (difference across cassette).
So if you have 50/34 and 11-28 that's
(50-34) + (28-11)
=16 + 17
= 33
Not all tiagra dérailleurs are the same, even within 10 speed there might be more than one, with different capacity.
You need the actual model number to check; it'll be stamped on somewhere.
If you've insufficient capacity, it's not the end of the world, but your chain may be slack in smaller combinations.
It's an RD-4700 rear derailleur. Cheers
P.s. I plan to put on a new chain when replacing the cassette.
4700 seems to have a short and medium length ("GS" and "SS")
SS has capacity 33
https://bike.shimano.com/en-EU/product/component/tiagra-4700/RD-4700-SS.html
GS has 41
https://bike.shimano.com/en-EU/product/component/tiagra-4700/RD-4700-GS.html
The SS is also only rated to 28T maximum cassette.
You need a GS for the larger cassette (SS might work but you're a long way from the spec range).
It's likely if the bike came with a 28 you have the SS, so you probably need a new derailleur.
Yes chainset is 50/34 as I thought it was.I need to do a count of the teeth on the chainset (i think it's 50/34 but I'm not sure), then i can find out the capacity.
Looks to be a short cage derailleur, might be OK with a 32 but I reckon 34 is pushing it.
Swapping the derailleur for a long cage version is fairly straightforward, but it depends how much you are willing to spend - they're around £40 I think.
Also wins this weeks prize for filthiest drive-chain.....
