Andy in Sig
Vice President in Exile
- Sigmaringen, Germany
Kirstie said:Cathryn have you ever tried ginger champagne - it's a cocktail, and is absolutely lethal. All you do is grate a load of raw ginger into a cocktail shaker, and mash it with a pestle so that the juice comes out. Then pour a shot of chilled vodka over the ginger per person. Give it a shake, and strain it out into the glasses. Then top it up with champagne...mmmmmm
There's a gadget you can get which saves you the mortar and pestle bit. It's a little bowl made by Kyocera out of some special ceramic. You peel your ginger and rub it on the raised spiky bits in the middle where the fibrous bits are retained by the spikes and the usable stuff collects in the ring around the sides. You've just got to be careful with your fingers when the ginger is nearly rubbed away: I once ended up with ginger a la blood.
