barrymanifold
- st helens
How much do you put on the pad ie thickness and where abouts on the pad. Just in a certain area or all over .Thanks.
How much do you put on the pad .
Thanks for that info you would think that would be writen on the tin.none - the pad will just absorb it, rendering the application pointless. Put it on your skin.
Exactly how i use it too. I do wonder if it would be worth taking a little with me on big rides for a top up.none - the pad will just absorb it, rendering the application pointless. Put it on your skin.
And if you don't want to waste your hard earned cash on branded creams - Vasaline does just as good a job.
ugh... why not go the whole hog and just use lithium grease....??
Avoid a chaffed undercarrage and treat depression in one foul swoop.![]()
