GreigM
- Cowdenbeath, Fife
I went with 32 on the back, struggle on hills as well, does make it a bit easier but I still have to stop for a breather now and then
Yes I have one on my mountain bikeI think the widest ratio 9 speed is a 12-36, which should get you up practically anything. You will need an MTB rear mech, and a longer chain, but it will be geared as wide as possible.
Hi folks, I'm looking for advice on gearing and chainsets for my bike. When I bought it (an Orbea Avant road bike) it came with the factory fitted chainsets and gears. They are Shimano Sora 3550 34/50 chain rings and 12-27, 9 speed rear cartridge
When I'm out on the bike, everything's ok I get on fine but the problem is this, I'm not fit enough at the moment to climb reasonably decent hills, my legs absolutely ache and I inevitably have to stop. Now I know I have to improve my level of fitness, that's obvious, plus I need to improve on the distance and time I'm on the bike. I can do all that.
My query is, can I change the rear gearing sprockets to make climbing a wee bit easier till I improve and what would be the best combination to go for.
The bike came with the Shimano Sora/Claris set up but I really don't know what to go for or what I actually need. I take it the cartridges can be changed. What would suit me better as I don't understand the gearing correctly. Is there a thread I can read so I can understand it better?
Any advice and help ppreciated, thanks. Hutch.
I suspect you're saying that tongue in cheek, but I suspect 99% of folk on here would say, there are no rules and if it works for you, that's all that matters.Hi..........
Late middle-aged cyclist here................
Yup-It is now easier than ever to get some old-bloke-gearing on yer road bike!
Pay no attention to Velominato types and their HTFU suffering ethos!
I have got weak spindlely 60 yr. old legs but just love to ride my road bike. I It has a triple 50-39-30 chainset and I i have retro-fitted it with an 11-30 cassette which gives me a 1=1 climbing gear. It's a god-send where I live on the edge of Dartmoor! I could probably even go to a 32t rear cassette? Absolute heresy!! MTB gearing for chrisake!!!!
It runs flawlessly. All I had to do was replace the rear derailleur with a 'long-cage' version to handle the extra chain length to cover all the gearing options. Since road-biking had its renaissance a few years back, Shimano (in particular) started producing gearing that catered for less than Bronzed-Adonis 20-something riders and all credit to them. Claris-Sora-Tiagra-105 gearing system can all be tweaked now to to handle what the continentals call 'alpine gearing' but which Brit roadies call 'old-man' gearing.
Suffer not and ignore those elitist velominati gain-sayers. Ride the gears you need. It IS all do-able!
Good luck and Happy Ridinge.
w
Whereas I would say exactly the opposite ... make sure that you are not overgeared, as avoiding steep hills because you can't get up them will do SFA for your fitness!With a bit of riding time / practice , you should be able to get up pretty much anything you'll encounter on these shores, with the 34 ring and up to the 27 rear sprocket. I'd say try to avoid low balling your gearing, as that will be counter productive in the long term.
Why do you say that?I'd say try to avoid low balling your gearing, as that will be counter productive in the long term.
"You" could be anything from an 18 to an 81 year old.One of my bikes has a Sora nine speed set up, with a triple up front, and a 12:27 cassette. It's the bike I use when I'm reccy ing an unknown route, and I'm not sure of the hillyness. With a bit of riding time / practice , you should be able to get up pretty much anything you'll encounter on these shores, with the 34 ring and up to the 27 rear sprocket. I'd say try to avoid low balling your gearing, as that will be counter productive in the long term.
