Certifythat
Hello what tool would I need to remove this chainset from the bottom bracket? It's a shimano sora, photos below.
That's an Octalink BB which I believe is the same tool required for a square taper. Although there is a work around using the crank retaining bolt.
Hello and to CC
The BBR60 is part of the Shimano Hollowtech II system and only works with HT2 style cranks. The BB unit is designed to fit into a standard thread frame sames as the square taper and Octalink BB unit.Slight off-topic question: is it possible to remove a square taper bottom bracket and replace it with a threaded bb (such as a shimano bbr60)?
Thanks!The BBR60 is part of the Shimano Hollowtech II system and only works with HT2 style cranks. The BB unit is designed to fit into a standard thread frame sames as the square taper and Octalink BB unit.
Many regard the ST as more durable and less bothersome.
Straight swap. You just need get the correct BB width in Hollowtech. Different for road and mountain bikes.Thanks!
So you're saying the threads are the same and therefore it is possible to replace square taper to a BBR60. Although if I decide to do that I will of course need to change the cranks.
Great, thanks for the explanation
